S6 MaxV
True Vision. Smarter Action
Watch the Video >
Purchase Now >
Digital Trends © 2020 Designtechnica Corp. Used under License.
Another level of intelligence
Twin cameras revolutionize your robot vacuuming experience, adding advanced features and bringing more peace of mind than ever before. Proprietary ReactiveAITM obstacle avoidance makes dodging obstacles automatic. Suction is stronger for a deeper clean. And an electronic water tank makes mopping smarter and more customizable. Roborock S6 MaxV takes home robotics to another level of intelligence.
Intelligent Obstacle Avoidance
Advanced Obstacle Recognition
Powerful Qualcomm® Processing
25% More Suction Power
Smart Mopping Add-On
Two Eyes to See
There’s a reason all mammals have two eyes - stereoscopic vision means depth perception. Using dual cameras, S6 MaxV not only sees obstacles in its path. It accurately estimates their location and size and reroutes its course around them. All in the blink of an eye. Equipped with infrared imaging, it can also see in the dark. Combined with Roborock’s renowned PreciSenseTM LiDAR navigation system, home navigation is fast and efficient every time, day or night.
Two Eyes to See
Seeing is Knowing
ReactiveAI is powered by a Qualcomm® APQ8053 processor chip, which performs 50% better than the one found in the S6, driving a Tensorflow convolutional neural network employing the latest deep learning architecture. It has been trained on tens of thousands of real-world images, so it can recognize and avoid common home hazards that may trip up other robots. From stray shoes to pedestals, to cables, and more. Even pet waste.
*Based on manufacturer’s internal testing using patterned, textured, high contrast objects in a well-lit environment. Object recognition accuracy will vary due to environmental factors.
Avoiding the Unknown
Depth perception means S6 MaxV avoids more than what it recognizes. Any object – down to as small as 5cm (2in) wide and 3cm (1.1in) tall – can be seen and bypassed. It’ll safely work its way around forgotten toys, pet bowls, misplaced cups of morning coffee. Ideal for busy homes.
*Based on manufacturer’s internal testing using patterned, textured, high contrast objects in a well-lit environment. Objects must be between 3-8cm tall, and wider than 5cm.
Built for Privacy
When it comes to a camera in the home, privacy and security are critical. Every image ReactiveAI processes is captured and deleted in an instant.1 Not only that, S6 MaxV is certified by TUV Rheinland as a safe smart home product and keeps your data safe and secure.
Nothing is ever duplicated
Nothing is ever stored
Nothing is sent to the cloud
What Waits at Home
See what obstacles are on your floors with icons2 placed directly onto the screen. Viewed along with the route map, what S6 MaxV has seen and the routes it has taken is instantly clear. Showing you any problems that need your attention and surprises lying in wait.
Suction to the Max
The strongest fan in a Roborock vacuum takes a bow. This 2500Pa3 HyperForceTM stormer is 25% more powerful than in the Roborock S6, giving S6 MaxV the grunt to better capture fine dust from floors and reach deeper into carpets.
2500Pa
Max Suction3
180 minutes
Maximum runtime4
240sqm
Maximum vacuuming area(2580sqft)4
25%
More Suction
Reach More Floors
Multi-level Mapping systems use PreciSenseTM LiDAR and visual scene recognition to recognize different levels of a home automatically5. Every floor can have independent No-Go Zones, Invisible Walls, and No-Mop Zones. S6 MaxV locates them all without you needing to open the Roborock app.
Genius Level Mopping
Click in the 297ml SnapMopTM system to unlock a suite of advanced mopping features. Set room-specific mopping schedules. Tailor water flow by room. Use No-Mop Zones to keep your carpets dry, and more. All controlled in-app.
200sqm
Suitable for homes up to (2150sqft)6
Reach More Floors
200sqm
Check in from Afar
Look around your home even when you're away. Fire up the Roborock app and drive around seeing what S6 MaxV sees. Make sure you've closed your doors, reassure yourself that your home is as you left it, or check in on the mischief your pets are up to. Even send a voice message to tell them you'll be home soon.7
Never-Ending Learning
Roborock engineers are always adding more common home items to ReactiveAI. Ready for download to S6 MaxV robots around the globe wirelessly.
Automatic Room Recognition
Ultra-Quiet 67dB8 Mode6
Extra-large 5200mAh battery
Washable E11 Rated9 Filter
PreciSense Sensor Array
ScratchSafeTM Wheels and Brushes
1.
Some optional settings and features may require additional data collection and processing.
2.
Actual icons shown in-app may differ from pictured.
3.
Tested internally by the manufacturer according to IEC 62885-2:2016 / 5.8 standards.
4.
Based on internal testing carried out by the manufacturer in Quiet mode on hard floors with a full battery and with no mop system attached. Actual results may vary according to the home environment.
5.
Up to 4-maps supported. Each level must be individually set up before use.
6.
Based on internal testing carried out on hard floors with a full water tank, full battery, and low water flow. Actual results may vary, depending on the room characteristics. Range is an estimate based on the assumption that 20% of the area is covered by furniture and will not need to be mopped.
7.
Only available when using the Roborock app.
8.
Tested internally by the manufacturer in balanced mode according to QB/T 4833 standards
9.
Produced and tested by an independent third party in accordance with EN 1822-1:2009 standards.
