Black Friday Lucky Draw!
Flex Your Clean
Introducing Roborock Flexi - the ultimate flexible solution for all your cleaning needs. Leveraging Roborock's vast expertise in home cleaning, it excels in handling wet and dry messes, delivering edge-to-edge cleaning performance, and effortlessly navigating beneath low-profile furniture. Enhanced with smart features like adaptive cleaning and self-cleaning, plus app compatibility, it offers effortless and worry-free operation.
Edge-to-Edge Cleaning: No Corner Left Untouched
Reaches Everywhere, Even Under Low Furniture
DirTect™: Automatically Adapts Cleaning and Self-Cleaning
Intelligent App and Voice Alerts for a Convenient Clean
error
One-Stroke Wet & Dry Cleaning
Cleaning should be efficient, so your precious time is spent on more important matters. From cooking mess to your little ones’ playful chaos, Roborock Flexi has it all covered with a single stroke. With 17,000 Pa1 suction power, it’s ensured to meet your high standards of home cleanliness and tidiness.
With DirTect™ adaptive cleaning capability, Roborock Flexi adjusts its cleaning power according to dirt levels on the floor, ensuring a thorough and time-saving cleaning experience. When self-cleaning at the base, DirTect™ checks if your roller has been cleaned effectively and switches to Deep Clean mode if it detects that the roller is still dirty after washing.
Always Clean, Always Fresh
Incorporating Roborock’s automatic self-drying & cleaning technology for wet-dry vacuums, Roborock Flexi self-cleans with a roller scrape and water spray module, ensuring a sparkling clean result while cleaning your floor.
55℃
60℃
Hot Water Self-cleaning
30 min
Auto Brush-Drying
99.9%4
Bacteria Removal Rate
With Roborock Flexi’s hot water self-cleaning and hot air self-drying feature, the roller is being scraped and washed in two directions with 60℃2 (140℉) hot water, complemented by the flow of 55℃3 (131℉) heated air, guaranteeing a hygiene and odor-free experience in 30 min.
15 cm5
Flexibility is the Key
Roborock Flexi features FlatReach™ technology for thorough cleaning under low furniture.
Roborock Flexi easily reaches edges and corners with side margins of less than 1 mm6.
All in Reach, All in Sound
With an LED screen accessible at your fingertips, monitoring modes and status becomes effortless. Roborock Flexi also provides real-time updates and operational reminders through convenient voice alerts.
Auto
Cleaning rollers
Empty the dirty water tank
Effortless Clean, Now Elevated with Intelligence
RoomTemperature
Warm
Hot
Maintenance
50%
75%
Start Time
16: 47
Repeat
Weekdays
Your Cleaning, Your Way
The Roborock App tailors the cleaning experience to your precise requirements. Unlock a range of intelligent features for customization, including a self-drying and cleaning timer, water temperature adjustment, suction power control, and more.
Long-Lasting Cleanups
With a substantial 50 min battery life, it delivers prolonged cleaning sessions without interruption, enabling an extensive cleaning coverage (420 sqm/ 4520 sqft7) before requiring recharging.
730 ml
Clean Tank size
50 min8
Battery Life
450 ml
Dirty Tank Size
Cleaning That Lasts
Up to 50 min Battery Life
30 min Auto Brush-Drying
5 kg Weight
730 ml Clean Water Tank Size
450 ml Dirty Tank Size
Double Edges Cleaning Design
Hot Air Self-Drying
Hot Water Self-Washing
SlideTech Adaptive Wheels
Built-in Headlight
App Compatibility
4.7 kg Weight
Hot Air Self-Drying
App Compatibility
Up to 40 min Battery Life
60 min Auto Brush-Drying
4 kg Weight
620 ml Clean Water Tank Size
400 ml Dirty Tank Size
Single Side Edge Cleaning
Hot Air Self-Drying
Standard Self-Washing
2. Based on internal testing, the water in the clean water tank can be heated up to 60℃ at standard room temperature. The actual temperature will vary due to environmental factors.
3. Based on internal testing, the water in the clean water tank can be heated up to 55℃ at standard room temperature. The actual temperature will vary due to environmental factors.
4. Based on testing carried out by TUV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.9% of bacteria on the roller are effectively removed. Test Report number: 244555550b3 001. Actual results may vary according to the home environment.
6. Based on internal testing. Actual results may vary depending on environmental factors.
7. Based on internal testing carried out by the manufacturer under ECO mode.
8. Based on internal testing carried out by the manufacturer under ECO mode.
