Skip to content
Start Prime Day Sale
Roborock Qrevo Edge Series
Elevate Clean, Untangle Life
Introducing the Roborock Qrevo Edge Series, bringing you the best in precision and power. Featuring the Dual Anti-Tangle System, it effortlessly prevents hair tangles for thorough, hassle-free cleaning. Boasting 18,500 Pa HyperForce® suction and advanced FlexiArm™ Technology, every corner of your home receives impeccable care. Experience an added edge in home cleaning.
  • Equipped with the DuoDivide™ Main Brush and FlexiArm™ Arc Side Brush, ensuring tangle-free cleaning.
  • Seamlessly adapts to various home environments with smooth movement.
*Available exclusively on the Roborock Qrevo Edge model.
Industry-Leading
  • Delivers unmatched power for a deep and effective clean.
  • Features an extendable side brush and mop for precise cleaning in every corner.
Multifunctional Dock 3.0
  • Enhanced 75°C hot water mop washing for a deep, hygienic clean of your mops and floors.
Find the Right Model for You
Snag-Free, Smooth Cleaning
Breeze Through Tangles
Enjoy seamless, tangle-free cleaning with Roborock's revolutionary dual anti-tangle system. Featuring both a main and side brush, it’s designed to tackle long hair and pet fur.
Featuring dual parallel short bristle rollers with spiral blades, the DuoDivide™ Brush efficiently channels hairs to the central dustbin inlet, where powerful suction swiftly clears it away. Certified by SGS and TUV, this brush excels with its unmatched cleaning performance and cutting-edge anti-tangle technology, setting a new standard for effortless cleaning.
100% Hair Removal Rate1
0% Hair Tangling Rate2
The innovative arc-shaped asymmetric brush generates centrifugal force during rotation, guiding hairs to the bristle ends and preventing tangling. Certified by SGS and TUV, this design delivers effective, tangle-free cleaning with every pass.
0% Hair Tangling Rate3
Easy-to-Maintain Omni-Wheel
The enhanced omnidirectional wheel is paired with a cleaning brush that automatically cleans the wheel during use, simplifying maintenance.
Superior Performance, Beyond Expectations
Boost Your Cleaning Game
The Roborock Qrevo Edge Series delivers impressive cleaning power with 18,500 Pa HyperForce® suction. Combined with the DuoDivide™ bristle brush, it conquers tough cleaning challenges on carpets and hard floor gaps, ensuring no debris stands a chance.
18,500Pa HyperForce® Suction4
99.5% Hair Removal Rate on Carpet5
Address Every Area
Roborock's exclusive FlexiArm™ Arc Side Brush and Edge Mopping System offers supreme thorough cleaning coverage, leaving behind no dirt by eliminating blind spots.
100% Edge and Corner Coverage6
0mm Along the Edge and Corner6
When corners are detected, the arc side brush quickly extends to sweep away debris, ensuring a deeper clean.
FlexiArm™ Mop
The extendable right-side mop precisely cleans along edges and adjusts dynamically to tackle corners.
Liftable Spinning Mops
Achieve Spotless Floors
Enjoy effortless deep cleaning as the dual mops rotate with consistent pressure and humidity, seamlessly lifting and removing stains.
200 RPM Spinning Speed7
10 mm Mop Lifting8
30 Levels Water Flow Options
Climb to a New Level of Clean
AdaptiLift™ Chassis
Elevate Your Cleaning Solutions
Transform your cleaning with the industry-first9 AdaptiLift™ Chassis. This cutting-edge system boasts independently adjustable three-wheel control, enabling the chassis to lift by 10mm10 or elevate the front, rear, left, or right sections. Experience unparalleled adaptability to any home environment and achieve optimal cleaning coverage with ease.
High thresholds are no longer a challenge with the AdaptiLift™ Chassis. It automatically lifts the omni-wheel to handle standard thresholds up to 3cm11 and complex double-layer thresholds up to 4cm12, the highest in the industry13, ensuring smooth movement across all surfaces.
Mid-to-High-Pile Carpet Cleaning
With the AdaptiLift™ Chassis’ 10mm elevation capability, cleaning performance is enhanced on mid-to-high-pile carpets. This feature allows powerful suction to reach deep into carpet fibers, preventing clogging and delivering superior cleaning results for cleaner, more refreshed carpets.
*The mid-to-high-pile carpet cleaning settings need to be activated manually in the Roborock app.
Liftable Brush and Mops
Customized Cleaning for Every Challenge
The brush and mops can be lifted automatically for different cleaning scenarios to maximize cleaning effectiveness while avoiding stains after a cleanup.
*The liftable brush and chassis are available exclusively on the Roborock Qrevo Edge model.
Chassis & Mops Lifted
Mops lifted
Brush lifted
Brush & Mops Lifted
10mm Chassis Lifting
10mm Mop Lifting
10mm Mop Lifting
Mops Lifted This is a image This is a image low-pile carpet This is a image This is a image
Mops & Chassis Lifted This is a image mid-to-high-pile carpet
Brush Lifted This is a image This is a image
Mops Lifted Mops & Chassis Lifted Brush Lifted
Vacuum-only This is a image
Mop-only This is a image
Carpet cleaning This is a image low-pile carpet This is a image mid-to-high-pile carpet
Returning to dock This is a image This is a image
Mop drying This is a image
Engineered for Ease of Use
Stress-Free Cleaning Companion
The upgraded Multifunctional Dock 3.0 features 167°F (75°C) hot water mop washing and self-cleaning capabilities, for an enhanced truly hands-free cleaning experience with improved power and intelligence.
This is a image 167°F (75°C) Hot Water Mop Washing
This is a image Dock Self-Cleaning with Hot Water
This is a image Warm Air Drying
Exceptional Stain and Bacteria Removal
Effortlessly remove stubborn stains and greasy messes from mops with 167°F (75°C) hot water14, ideal for kitchens and dining areas. The high-temperature water eliminates over 99.99% of bacteria, ensuring superior hygiene. With three adjustable temperature settings, you're equipped for any cleaning challenge.
99.99% Bacteria Removal Rate15
Superior Cleaning Quality
Re-Wash
During mop washing, detection checks the level of dirt on the mops to determine if additional washing is required to ensure thorough cleanliness.
Re-Mop
In areas with stubborn dirt and stains, the floors will be mopped a second time to ensure they are thoroughly cleaned. *The automatic re-mopping feature needs to be activated manually in the Roborock app.
Discover Touchless Cleanliness
The dock base is effectively cleaned by the rotating scrapers and hot water, thanks to the incorporated self-driven cleaning module, reducing the need for manual maintenance.
Easy Handling, Superior Convenience
Warm Air Drying
Auto Tank Refilling
Detachable Base
Warm Air Drying Dries the mops and dock base completely with 113°F (45°C) of warm air16, preventing the growth of mold and unpleasant odors.
Auto Dust Emptying Allows for up to 65 days without manual emptying.17
Dries the mops and dock base completely with 113°F (45°C) of warm air16, preventing the growth of mold and unpleasant odors. Allows for up to 65 days without manual emptying.17 Fills the water tank automatically when needed. Easily remove the dock base for your cleaning convenience.
Advanced Capabilities
That Lead the Way
Say "Hello Rocky" for Help
Just say "Hello Rocky" to initiate cleanups, adjust settings for different scenarios, or direct the robot to where it's needed, all hands-free. Enjoy the convenience of voice control without needing WiFi or your phone, even when offline.
"Clean here"
"Clean the kitchen"
"Just vacuum"
Start and Pause Cleaning
Cleanups by Call
Specify Room Cleaning
Adjust Cleaning Modes
Mop Washing and Drying
*Intelligent voice assistant is available in selected languages, please refer to the Roborock app for more information. *The commands shown on this page are used as examples only. The actual performance may vary with use conditions.
Navigate Any Home Terrain
Equipped with structured light and an RGB camera, the robot detects and avoids 62 types of objects across 20 categories18. It efficiently navigates around obstacles, reducing the need for manual intervention in both well-lit and dim environments.
Effortless Navigation for Everyday Cleaning
Using structured light to detect and steer clear of common obstacles, the robot ensures a smooth, worry-free cleaning experience—even without the need to clear the floor first.
Roborock Qrevo Edge
Other Models
62types
Objects Recognizable
PreciSense® LiDAR Navigation
Pet-Friendly
Delight in This is a image Pet-Friendly Features
Quiet Cleaning
Roborock Qrevo Edge features brushless motors and an advanced hardware design that minimizes noise during operation. With mopping noise levels as low as 55dB19, it provides a notably quiet cleaning experience, keeping your pets calm and undisturbed.
Video Call
Automatic Pet Recognition
Pet Snaps
Search for the Pet
Clean As You Wish
Roborock SmartPlan™ Technology
Tailored cleaning modes to your habits, room types, and floor materials, Roborock SmartPlan™ intelligently generates cleaning modes, and adjusts settings and preferences automatically. Enjoy worry-free cleaning with no need for manual mode adjustments.
Real-Time Cleaning Progress Display
Utilize the app’s dynamic progress bar to effortlessly monitor the robot's cleaning status. Receive real-time updates directly on the homepage, optimizing efficiency and saving time.
Temporary Cleaning
Temporary Cleaning
Always Within Reach
Third-Party Voice Control
Launcher Widgets
Apple Watch App
Matter Protocol
Step into the Future of Smart Living Unlock new possibilities with the Matter protocol and Roborock Qrevo Edge Series. Effortlessly control your robot vacuum and other smart home devices with seamless compatibility. Experience the convenience and efficiency of a fully integrated smart home.
  • Customizable App Features
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
Roborock Qrevo Edge
352*347*103 mm
340*487*521 mm
Roborock Qrevo Edge S5A
352*352*98 mm
340*487*521 mm
Sign up for product availability alerts, exclusive offers, campaigns, and more.
** Use of this product requires the Roborock app. The product will not function as intended without downloading the app and agreeing to the app’s Terms and Conditions.
1. Certified No.PT/24/GEN/0454 by SGS. Actual results may vary according to the home environment.
2. Certified No.PT/24/GEN/0453 by SGS. Actual results may vary according to the home environment.
3. Certified No.PT/24/GEN/0455 by SGS. Actual results may vary according to the home environment.
8. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
10. Based on internal testing carried out by the manufacturer, the chassis can be lifted up to 10mm. Actual results may vary according to the home environment.
12. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
13. Based on research conducted by the manufacturer as of Sept 1, 2024, within the robot vacuum category.
15. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Certification ID: 0000086976 (Roborock Qrevo Edge); 0000087862 (other models). Actual results may vary according to the home environment.
