Skip to content
Start Anniversary Sale
Roborock Q7 Series
Roborock Q7 Series
A Cleaning Solution for Every Home
Q7 Series
Roborock Q7 Series
10,000 Pa
HyperForce® Suction
Roborock Q7 Series
8,000 Pa
HyperForce® Suction
Roborock Q7 Series
Dual Anti-Tangle System
Roborock Q7 Series
Three Levels of
Water Flow
Roborock Q7 Series
PreciSense® LiDAR
Navigation
Roborock Q7 Series
Self-Emptying Dock
Roborock Q7 Series
Flexible App Control
Available in 2 Options
 Roborock Q7 M5 / Roborock Q7 L5
 Roborock Q7 M5+ / Roborock Q7 L5+
Impressive HyperForce® Suction Power
Root Out Hair From
Crevices and Carpets
Suction Power
Root Out Hair
From Crevices and Carpets
Roborock Q7 Series
Roborock Q7 M5(+)
10,000 Pa
HyperForce® Suction Power 1
Roborock Q7 L5(+)
With an impressive 8,000 Pa suction, this powerful system is built to lift hair and debris from floor crevices and deep within carpets.
8,000 Pa
Fewer Tangle. Fewer Trouble.
Dual Anti-Tangle
Design
Roborock Q7 Series
Equipped with a JawScrapers™ Comb anti-tangle main brush and an anti-tangle side brush, this advanced system ensures smoother operation and reduced maintenance.
Q7 Series
JawScrapers™ Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
Consistent Water Flow Mopping
Consistent Water
Flow Mopping
Removes Dust You
Hardly See
Roborock Q7 Series
3 Levels
Water Flow Options
Detachable Mop Design
For Versatile Cleaning Needs
Roborock Q7 Series
Anti Scale Design
Built-in nonhazardous3 descalers bag prevent scale formation and protect pipes from clogging for up to 3 years4.
Roborock Q7 M5/L5
Roborock Q7 M5/L5(+)
Anti Scale Design Anti Scale Design
Roborock Q7 M5/L5
Roborock Q7 Series
PreciSense® LiDAR Navigation
Learn, Navigate,
Remember
Roborock Q7 Series
Roborock Q7 Series
RockDock® Plus
Handles Dirty
Work for You
Q7 Series
Experience hassle-free cleaning convenience with the RockDock® Plus. The large dust bag lets you clean for up to 7-9 weeks without emptying5, making it ideal for families with pets and reducing allergens.6
Q7 Series
Tap, Tap, Clean
Roborock Q7 Series
Q7 Series
Temporary Cleaning
Temporary Cleaning
Q7 Series
Auto Boost on Carpet
Q7 Series
High-Intensity Mopping
Q7 Series
Cleans Along Floor Direction
Q7 Series
Temporary Cleaning
Temporary Cleaning
Q7 Series
Q7 Series
Q7 Series
Robot Vacuum
325 * 325 * 99 mm
160 * 70 * 101 mm
Roborock Q7 M5 / Roborock Q7 L5 Dimensions
Robot Vacuum
325 * 325 * 99 mm
212 * 178 * 259 mm
Roborock Q7 M5+ / Roborock Q7 L5+ Dimensions
  • Customizable Cleaning Modes
  • Off-Peak Charging
  • Child Lock
STAY TUNED IN!
**Use of this product requires the Roborock app. The product will not function as intended without downloading the app and agreeing to the app’s Terms and Conditions.
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN25I41V 001. The pet hair tangle rate is 0%, while short human hair (20 cm) tangle rate is 0.063%. Actual results may vary depending on usage conditions.
Back to Top
