Skip to content
Start Prime Day Sale
Roborock Qrevo Slim
Slim. Smart. Spotless.
Meet the Roborock Qrevo Slim, a new era of smart cleaning. With a sleek 8.2cm profile and innovative 3D sensing tech, it navigates and dodges obstacles like a pro. Its FlexiArm™ technology and DuoRoller Riser™ Brush effortlessly handle dirt and debris, while the 8-in-1 multifunctional dock makes upkeep a breeze.
Roborock Qrevo Slim with Refill & Drainage System
Next-Level Convenience Perfected
Building upon the maintenance-free dock features of the Roborock Qrevo Slim, we’ve introduced a refill and drainage variant, taking hands-free cleaning to new heights.
Auto Water Refill and Drain
The dock automatically refills the clean water and empties the used water during mop washing and wank refilling. No more manual refilling or draining – just peace of mind after every clean.
Auto Detergent Dispenser
Auto adds the optimal amount of detergent to the clean water tank for optimal cleaning results.
550ml
Detergent Tank Size
Compact Design
*Products with a Refill and Drainage system are only available in certain regions and countries.
550ml
Detergent Tank Size
Compact Design
Check Your Environment
Clean Water Inlet
Power Plug
Dirty Water Outlet
More than 120cm
5
More than 40cm
6
More than 41cm
Strong Wi-Fi coverage
Installation Requirements
  1. 1.Maintain a space of approximately 41cm in height, 40cm in length, and 120cm in width.
  2. 2.Position the dock on a hard and even floor (wood, tile, concrete, etc.), flush against a wall. Avoid placing it on soft surfaces (carpet, mat, etc.) and in narrow areas.
  4. 4.The height difference at any point on the drainage pipeline from the ground is recommended not to exceed 50cm.
  5. 5.The installation distance for the water refill and outlet pipes is recommended within 6 meters of the dock. If this is not possible, please contact customer service for consultation.
  7. 7.The pipeline layout should avoid passing through room doorways and corridors to prevent accidental breakage due to household traffic.
  8. 8.Ensure there are no thresholds, tracks, or steps higher than 2cm between the dock's installation site and the cleaning area to avoid the risk of entanglement or missed cleaning.
  9. 9.Before installation, disconnect the power supply of the dock. Turn off the main water supply switch, faucet switch, or angle valve switch in the house. Drain any remaining water from the pipes, connect the water lines, and ensure there are no leaks before powering on.
8.2cm Ultra-Slim Design
Slim and Spotless, Everywhere
Roborock Qrevo Slim packs a powerful punch in a sleek, low-profile 8.2cm(3.23inches) frame, designed to conquer hard-to-reach areas. It seamlessly glides under sofas, beds, and other low-clearance areas with its advanced locating and mapping capabilities, providing a truly complete cleaning experience.
StarSight™ Autonomous System
Industry-First Dual Light Solid-State LiDAR1
Pioneering Navigation System
Unlock Next-Gen 3D Sensing
As Roborock’s latest cutting-edge innovation, the sophisticated 3D Time-of-Flight (ToF) system provides a comprehensive 3D understanding of the surroundings, enabling precise navigation with pinpoint precision and accurate mapping, even in challenging areas around suspended cabinets and thin-legged furniture.
21x
Improved Sampling Frequency2
Enhanced Precision
The 3D sensing technology captures detailed information, including depth and height, ensuring accurate locating and mapping performance even in tricky areas.
Comprehensive Capabilities
The robot seamlessly navigates through your home and detects obstacles simultaneously.
Improved Coverage
The compact design empowers the robot to access previously hard-to-reach areas, such as under furniture, for improved cleaning coverage.
Advanced Obstacle Recognition
Roam Without a Hitch
Powered by 3D sensors that capture precise outlines of obstacles and an RGB camera for visual recognition, the robot reacts promptly to unexpected obstacles and small items. This advanced intelligence allows it to maneuver through your home without any hassle.
>21,600
Sensor Points*
73
Types of Objects Recognizable3
3x
Improved Small Object Avoidance4
*The Roborock Qrevo Slim uses a QVGA ToF sensor with 21600 sensor points.
Explore StarSight™ Autonomous System
FlexiArm™ Side Brush and Mop
Leave Dirt Nowhere to Hide
The FlexiArm™ technology empowers double robotic arms for the side brush and the mop to expertly sweep dirt from corners, edges, and under furniture. The flexible system ensures comprehensive cleaning coverage, eliminating blind spots for a meticulous whole-home clean.
Edge and Corner Coverage5
0 mm
Along the Edge and Corner5
Double the Power,
Double the Clean
The dual counter-rotating all-rubber brushes and 11,000 Pa suction power make the Roborock Qrevo Slim an outstanding cleaning force. It conquers dirt, hair, and debris across various floor types like hardwood, tile, and carpets for a pristine, flawless finish.
2x
All-Rubber Main Brush
HyperForce® Suction6
Less hair tangled with concealed scrapers
99%
Hair Pick-up Rate on Carpets7
Roborock Carpet Boost+ System™
Tailored for Easy Carpet Maintenance
Get better carpet care with a 99% hair pick-up rate using the Roborock Carpet Boost+ system™.
99%
Carpet Boost
Deep Carpet Cleaning
Vacuum Carpet First
Dual Spinning Mops
Tackle Tough Stains and Grime
Elevate your cleaning routine with the dual spinning mops. Engineered to glide effortlessly across your floors, the mops apply constant pressure and humidity for a flawless shine.
200 RPM
Spinning Speed8
10 mm
Mop Lifting9
30 Levels
Water Flow Options
Liftable Brushes and Mops
Designed for a Perfect Clean
The automatic lift capabilities for the brushes and mops optimize performance for different tasks and prevent stains after cleanup.
Brush Lifted
Mop Lifted
Brush & Mop Lifted
During Mop-only Mode
During Vacuum-only Mode During Carpet Cleaning During Mop Drying
When Returning to Dock
Brush Lifted
Mop Lifted
Brush & Mop Lifted
DirTect™ Technology
Adaptive Cleaning Intelligence
Dirt doesn’t stand a chance as the robot adapts its cleaning strategy based on the dirt type. Heavy dust? It cranks up the suction. Stubborn stains? It mops with increased water flow.10
Multifunctional Dock 3.0
8-in-1 Hands-Free Maintenance
Hot Water Mop Washing
Intelligent Dirt Detection
Self-Cleaning
Warm Air
Drying
Auto Tank
Refilling
Detachable Base
Faster Charging & Off-Peak Charging
The heated water effectively dissolves greasy stains and removes over 99.9% of bacteria from the mops, leaving your floors in dining areas and kitchen hygienically clean with minimal effort.
99.9%
Bacterial Removal Rate11
For Re-Wash
During mop washing, the system continuously monitors the dirt level to adjust the wash duration, guaranteeing your mops are thoroughly cleaned.
For Re-Mop
For floors with stubborn, heavy soiling, the dock automatically triggers an additional mopping pass to ensure a perfect clean.*
*The automatic re-mopping feature needs to be activated manually in the Roborock App.
Dock Self-Cleaning
With the motor-driven cleaning module, the dock base is cleaned effectively by rotating scrapers, eliminating the need for manual maintenance. All self-cleaning module accessories and the dock base itself are fully detachable for easy washing when needed.
Warm Air Drying Dries the mops and dock base completely with warm air, preventing the growth of mold and unpleasant odors.
Auto Dust Emptying Allows for up to 7 weeks without emptying.12
Auto Tank Refilling The water tank on the robot is refilled automatically.
Detachable Base The detachable dock base enables convenient cleaning as needed.
Fast Charging & Off-Peak Charging Saves you time and money with 30% fast charging and off-peak charging.13
Say “Hello Rocky” for Help
Just say the words “Hello Rocky” to kick off cleaning tasks and access more capabilities. Your voice-controlled companion is always ready to help, no network is required.
Start and Pause Cleaning
Cleanups by Call
Specify Room Cleaning
Adjust Cleaning Modes
Mop Washing and Drying
Tap. Tap. Clean.
  • Roborock SmartPlan™ Technology
  • Temporary Cleaning
  • Custom Cleaning Routines
With Roborock SmartPlan™ Mode on, the Roborock Qrevo Slim can handle the entire cleaning process automatically. All you need to do is select the cleaning area, and it will take care of the rest, determining how to clean automatically based on the environment. The “Temp Cleaning” function swiftly handles unexpected spills without disrupting your usual cleaning schedule.
You can also use the “Temp Skip” feature to bypass cleaning specific areas temporarily.
Personalize your cleaning routine with a preferred time, cleaning mode, cleaning direction, and the areas that need cleaning.
Roborock SmartPlan™ Technology With Roborock SmartPlan™ Mode on, the Roborock Qrevo Slim can handle the entire cleaning process automatically. All you need to do is select the cleaning area, and it will take care of the rest, determining how to clean automatically based on the environment.
Custom Cleaning Routines Personalize your cleaning routine with a preferred time, cleaning mode, cleaning direction, and the areas that need cleaning.
Purrfect Pal for Your Furry Friends
Video Call & Cruise
Whether you need to check in on your furry friends, schedule on-demand cruises, or manually control the robot’s patrols, it’s all just a tap away.
Video Call & Cruise
Pet and Pet Supply Recognition
It stops its main brush and moves aside in advance when approaching your beloved pets to avoid frightening them. And it will boost suction when cleaning around pet supplies for a thorough clean.14
Pet Snaps
Capture those adorable moments of your pets with Roborock Qrevo Slim. While tidying up your home, it can snap precious pics of your pets, readily available for you to download.
Search for the Pet
Are you concerned about your purring pal home alone? With a tap on the App, the robot will roam around your home to find your pet.
Elevate Smart Living with Matter Protocol
Embrace the power of Matter standard through the Roborock Qrevo Slim, leading you to boundless smart home possibilities. Say goodbye to the frustrations of limited compatibility as you effortlessly take control of your robot vacuum and other compatible devices. Discover the true convenience of a fully integrated smart home.
Always Within Reach
Roborock Qrevo Slim Robot 350 * 353 * 82 mm
Dock 340 * 487 * 521 mm
ScratchSafe® Wheels and Brush
Sensient® Sensor Array
Adaptive Route Algorithms
Quiet Mopping
Child Lock
Roborock Qrevo Slim Roborock Qrevo Master
8.2cm Robot Height
10.3cm Robot Height
PreciSense® LiDAR Navigation System
FlexiArm™ Edge Mop
FlexiArm™ Edge Mop
11,000 Pa HyperForce® Suction
10,000 Pa HyperForce® Suction
Intelligent Voice Assistant
Roborock Qrevo Slim
8.2cm Robot Height
FlexiArm™ Edge Mop
10.3cm Robot Height
FlexiArm™ Edge Mop
*Images are for illustration purposes only and may not exactly represent the product. **Use of this product requires the Roborock app. The product will not function as intended without downloading the app and agreeing to the app’s Terms and Conditions.
  1. Roborock was the first in the robot vacuum industry to implement 3D ToF functionality using a dual-transmitter approach, as the technology officially launched earlier in 2024.
  2. Based on internal testing carried out by the manufacturer according to the LDS sampling frequency calculation method.
  3. Based on internal testing carried out by the manufacturer, Roborock Qrevo Slim can see and bypass objects down to as small 3cm wide and 3cm tall. Recognition accuracy may vary depending on environmental factors.
  4. Based on internal testing carried out by the manufacturer, Roborock Qrevo Slim can see and bypass square building blocks down to as small 3cm wide and 3cm tall. The recognition accuracy is 3 times higher than S8 Pro Ultra.
  5. Certified by TÜV Rheinland. Test report number: No. CN24MQ0Y 001. Actual coverage depends on the environment.
  6. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021 / 5.11 standards, using Max+ mode with a full battery, the maximum suction power can be up to 11000 Pa.
  7. Based on internal testing using Max+ mode. Actual results may vary according to the home environment.
  8. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200 rpm.
  9. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10 mm.
  10. In mop-only and vacuum & mop mode, Roborock Qrevo Slim can clean dried stains with increased water flow.
  11. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default mode, over 99.9% of bacteria are effectively removed at the dock. Test Report number 326030784a 001. Actual results may vary according to the home environment.
  12. Actual emptying interval will depend on user habits and environmental factors.
  13. Compared to the Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
  14. To boost suction power around pet supplies, please activate the “Pet Supply Deep Cleaning” on the App.
Back to Top
