Skip to content
Start Prime Day Sale
Qrevo Edge 3 Pro
Cutting-Edge, Made Efficient.
Buy Now
Qrevo Edge 3 Pro
Designed for complex homes, it delivers powerful vacuuming and deep mopping—while climbing thresholds, gliding under furniture, and adapting across carpets. Qrevo Edge 3 Pro knows where to go, what to avoid, and finishes the job on its own.
Expanded Cleaning Reach
Climbs over high thresholds and slides under furniture with ease.
Powerful Suction & Tangle-Free Cleaning
Picks up dust and hair while helping prevent tangles.
Enhanced Mopping Performance
Delivers warm-water mopping with minimal water residue.
Advanced Carpet Cleaning
Built for Better Carpet Care
Intelligent Obstacle Handling
Sees more. Reacts smarter. Cleans better.
Hygienic Multifunctional Dock
212°F¹ Hot Water Mop Washing and Auto Detergent Dispenser for a deeper clean.
Clean More of Your Home,
Effortlessly.
AdaptiLift™ Chassis 3.0
Climbs Higher. Goes Further.
Powered by AdaptiLift™ Chassis 3.0 with a climbing arm, it lifts and climbs over high thresholds effortlessly—so cleaning doesn’t stop at boundaries.
1.77 inches + 1.69 inches
20,000+
Threshold Crossings Tested³
Sees Clearly, Even in Low Spaces
3.13 inches
Low-Clearance Access⁴
100,000+
Lift Cycles Tested⁵
Across Every Surface,
Into Every Corner.
36,000 Pa HyperForce Motor
Deep Cleaning, Made Effortless.
An ultra-powerful motor delivers consistent suction to lift dust, debris, and hair across every surface.
36,000 Pa
Max Digital Motor Power⁶
Dual Anti-Tangle System
No Tangles.
No Interruptions.
Designed to handle even long hair, the DuoDivide™ Main Brush and FlexiArm™ Arc Side Brush work together to prevent tangles and maintain continuous cleaning.
Hair Tangling Rate⁷
Hair Removal Rate⁸
Hair Tangling Rate⁹
Deeper Mopping. Less Residue.
30%
Less Water Residue¹⁰
14N
200 RPM
Spinning Speed¹²
Industry-First Dynamic Cleaning for Up to 1.18 inches Carpets
Automatically adjusts its chassis to maintain strong suction on carpets up to 1.18 inches¹³—delivering deeper, more consistent cleaning*.
Automatic Mop Detachment
Automatically detaches the mop in Vacuum Carpet First Mode*—keeping carpets dry and protected.
When Deep Carpet Cleaning Mode* is enabled, the main brush stays in a stable downward position on a second pass—improving debris pickup compared to its usual floating state.
prev prev hover
next next hover
FlexiArm™ Technology
Reaches Edges. Cleans Corners.
FlexiArm Arc Side Brush
Roborock’s FlexiArm™ Arc Side Brush and Edge Mopping System clean tightly along walls and into corners, while the extendable side brush reaches under toe-kick areas for more complete coverage.
Edge Mopping System
Edge and Corner Coverage¹⁴
0mm
Along the Edge and Corner¹⁵
Liftable Brush and Mops
Vacuum Only
Mop Mode
Clean Carpet
checked Mops detached
checked Main brush lowered
checked Main brush lifted
Handles Obstacles—
So You Don’t Have To.
Advanced Obstacle Avoidance
Powered by Reactive AI Obstacle Recognition, which combines structured light and an RGB camera, together with VertiBeam™ Lateral Obstacle Avoidance, it detects more obstacles near and far—even along walls and furniture—with minimal blind spots.
TUV Certified
More Objects Recognized
200 +
Previous-Generation Model¹⁶
300 +
Qrevo Edge 3 Pro¹⁷
Cleans Behind Curtains
With manual curtain marking in the app, it cleans behind curtains and soft partitions—covering hidden areas without the need to lift or adjust them.
Cleans What Gets Missed
If cleaning is temporarily blocked by people or pets, it continues elsewhere—and automatically returns to clean missed spots once the path is clear*.
Won’t Push Through Closed Doors
When doors are closed, it moves on instead of pushing or bumping—helping protect your doors while keeping cleaning smooth and uninterrupted.
Gets Itself Unstuck
Recognizes obstacles like chair legs, then intelligently adjusts its movement—using its liftable chassis and climbing arms to free itself and keep cleaning moving.
prev prev hover
next next hover
It Cleans.
Then It Cleans Itself.
Brand New Multifunctional Dock
212°F Hot-Water Mop Washing
Uses up to 212℉ hot water to loosen grease and stubborn residue for a more hygienic clean.
TUV Certified
Up to
212℉
Hot-Water Mop Washing¹
Bacteria Removal Rate¹⁸
Smart Mop-Washing Mode
Equipped with an auto detergent dispenser, the dock automatically adds cleaning solution for a more thorough and effortless mop cleaning
212°F Hot Water Dock Self-Cleaning
The dock base stays hygienic with up to 212°F¹ hot water and the self-cleaning module, reducing manual maintenance.
131°F Warm Air Drying
Dries the mops and dock base thoroughly with 131°F¹⁹ of warm air, preventing the growth of mold and unpleasant odors.
Warm Water Auto-Refilling
Allows for up to 65 days²⁰ without manual emptying.
Detachable Dock Base
Roborock APP
The Brain Behind Every Clean
Carpet Cleaning
Roborock SmartPlan™ 3.0
Roborock SmartPlan™ 3.0 automatically recognizes room types, learns your cleaning habits, and selects the optimal cleaning strategy for you—boosting suction when needed, rewashing the mop as required, and lowering power to reduce noise during Do-Not-Disturb periods.
Pet-Friendly Intelligence
Closer to Your Furry Friends
Automatic Pet Recognition
Pet Snaps
Search for the Pet
Video Call & Cruise
Pet Snaps
Search for the Pet
Video Call & Cruise
Everyday Features
Stain-Target AI Cleaning
Built-in Voice Assistant
Third-Party Control
Pet Care Hub
Designed for homes with pets, it brings cleaning settings, pet zones, and even pet albums together in one dedicated space within the app.
Key Specs
Qrevo Edge 3 Pro
Qrevo Edge 3 Pro
Qrevo Edge 3 Pro
13.86 × 13.78 × 3.14 in
15.83 × 19.45 × 17.72 in
* Images and videos are for illustration purposes only and may not exactly represent the product. The app interface, feature availability, and navigation paths are subject to change without notice.
1. Based on internal testing conducted by the manufacturer. The heating module can heat water up to 212°F under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual results may vary depending on usage and environmental conditions.
2. Based on internal testing by the manufacturer, under test conditions where the first threshold height does not exceed 1.77 inches, the gap depth between the two thresholds is greater than 4.72 inches and does not exceed 5.51 inches, and the second threshold height does not exceed 1.69 inches, the robot is capable of crossing double-layer thresholds with a combined height of up to 3.46 inches. Actual performance may vary depending on environmental conditions and actual user usage.
4. The body height of the robot vacuum is 3.14 inches. Due to slight vertical flexibility in the front structural components, the robot may achieve limited passive compression when entering low-clearance spaces, allowing access down to 3.13 inches. However, please note that scraping may occur. Actual performance may vary depending on environmental conditions.
7. Based on internal testing, the hair tangling rate was 0% using 0.1 g hair samples at each tested hair length (7.87 inches, 11.81 inches, and 15.75 inches) across all five operating modes under controlled test conditions. Actual results may vary depending on environmental conditions.
8. Based on internal testing, the hair removal rate reached 100% using 0.1 g hair samples at each tested hair length (7.87 inches, 11.81 inches, and 15.75 inches) under controlled test conditions. Actual results may vary depending on environmental conditions.
9. Based on internal testing, the hair tangling rate was 0% using 0.1 g hair samples at each tested hair length (7.87 inches, 11.81 inches, and 15.75 inches) across all five operating modes under controlled test conditions. Actual results may vary depending on environmental conditions.
13. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors. This feature is powered by Roborock’s AdaptiLift Chassis—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet-cleaning capability was officially introduced in Q3 2025.
16. Compared with the Roborock previous-generation model in the same Roborock product category under internal test conditions. Recognition accuracy may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 131°F under standard room temperature. Actual temperatures may vary due to environmental factors.
21. These carpet cleaning settings must be manually enabled and selected in the Roborock app. This feature is applicable to household carpets with pile heights of 1.18 inches or below, which covers the majority of carpets used in typical homes.
Back to Top
