Skip to content
Start Anniversary Sale
Roborock F25 Pure
Light, Easy, Spotless
Buy Now
Vacuum & Mop, All in One
Picks up dry dust and wet messes in one machine.¹
JawScrapers™ Anti-Tangle Design
Zero hair tangles.² Reduce manual cleanup.
Dock-Based Self-Cleaning System
Dual-direction roller washing for thorough cleaning.
FlatReach™ 2.0
FlatReach™ 2.0
180° full-flat design cleans under furniture with ease.
Up to 38-Minute Runtime³
Cleans up to 284 sqm on a single charge.⁴
Optimized Glide Wheels
Glides effortlessly around your home.
0 mm Edge-to-Edge Cleaning⁵
Cleans along baseboards and into corners.
Deep Clean,
Now Made Simple
Barefoot-Ready Cleaning for Everyday Life
Skip the extra steps. Roborock F25 Pure vacuums and mops at the same time to pick up dust, spills, and everyday messes in one machine.¹
20 N
Downward Pressure⁶
450 RPM
Cleaning Strokes⁷
20,000 Pa
Suction Power⁸
>99.99%
Bacteria Removal Rate⁹
Scrape, Sweep, and Stay Tangle-Free
Hair buildup can make roller maintenance a hassle.
JawScrapers™ combines shark-tooth blades with constant-pressure scrapers to capture hair before it wraps around the roller and minimize water stains on the floor¹⁰, reducing maintenance needs.
Tangle Rate²
From Everyday Dust to Unexpected Spills
Whether it’s breakfast spills in the kitchen, dust under the sofa, or everyday dirt, Roborock F25 Pure tackles wet and dry messes effortlessly, so your floors stay clean with less effort.
Clean From
Room to Room
Clean From Room to Room
With up to 38 minutes of runtime in ECO mode, you can clean multiple rooms on a single charge without stopping to recharge.
Up to
38 min
Runtime on a Single Charge³
Up to
284 sq. m (3,056 sq. ft.)
Cleaning Area per Charge⁴
Dock It, Press It,
It Cleans Itself
Stay Fresh Between Every Clean
Simply dock the vacuum and press the self-cleaning button to automatically rinse the roller and remove excess water.
>99.99%
Bacteria Removal Rate¹¹
99%
Roller Self-Cleaning Efficiency¹²
TÜV SÜD certification
>99.99%
99%
* After each cleaning cycle, remove the roller and place it in the holder to dry thoroughly
Reach More Places,
Leave Less Behind
FlatReach™ 2.0
Cleans Low Areas with Ease
Roborock F25 Pure smoothly lays flat to 180°, maintaining suction even under furniture. At just 4.9 inches high¹³, it easily reaches under beds, sofas, and other low spaces.
4.9 inches
Body Height
180°
Lay Flat
Edge-to-Edge Cleaning: From Baseboards to Corners
Dust tends to accumulate along walls and corners. 0mm⁵ edge-to-edge cleaning helps pick up dust along walls and corners.
Cleaning Made Easy,
Every Step of the Way
Cleaning Made Easy, Every Step of the Way
70° Swivel Design
With a lowered center of gravity and a 70° swivel design¹⁴, it turns smoothly around furniture and through tight spaces.
Optimized Glide Wheels reduce push effort, move smoothly over floor seams, and clear thresholds effortlessly for easier movement around your home.
Effortless Glide
Easier pushes from room to room.
Stable Roll
Stable movement across different surfaces.
Enhanced Obstacle Clearance
Glide over thresholds smoothly.
Balanced for Effortless Handling
By lowering the center of gravity for a grounded, stable feel, the design enhances maneuverability, making the device feel lighter in your hand and steadier on the floor.
Always Ready,
Always in the Know
Voice Alert
Voice alerts keep you informed without stopping to check the display.
Indicator Display for Status Checks
Check cleaning status and settings at a glance with a clear, easy-to-read display.
Specs
Roborock F25 Pure
Roborock F25 Pure
Roborock F25 Pure
Wet & Dry Vacuum Cleaner
10.35" × 9.53" × 43.31" (263 × 242 × 1100 mm)
Vacuum Cleaner with Dock
11.81" × 11.57" × 44.06" (300 × 294 × 1119 mm)
1. Based on internal testing conducted by the manufacturer using common household stains such as coffee, ketchup, and mustard. Actual performance may vary depending on environmental conditions.
2. Based on SGS testing, the hair tangling rate is 0% when tested with 2,000 strands of 50 cm dry and wet hair across two operating modes under controlled testing conditions. Report No.: SHES241002115877. Actual performance may vary depending on environmental conditions.
3. Based on internal testing conducted by the manufacturer in ECO mode with a gentle suction setting. Actual performance may vary depending on environmental conditions.
4. Based on internal testing conducted by the manufacturer while operating the machine in ECO mode at minimum suction power and a speed of 0.5m/s. Actual results may vary depending on the home environment, level of cleanliness, cleaning habits, and other factors.
5. Based on internal testing conducted by the manufacturer. Edge cleaning performance applies to both left and right sides. Actual results may vary depending on environmental conditions.
6. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
7. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
8. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
9. Based on testing carried out by TÜV SÜD on Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae and Escherichia coli in MAX mode, over 99.99% of bacteria on the floor are effectively removed. Report No.: 4840125838801. Actual results may vary depending on the home environment.
10. Based on internal testing conducted by the manufacturer. Operated in place for 2 minutes to ensure sufficient wetting, then cleaned the tile surface at 0.2 m/s. The cleaned area was immediately wiped with paper towels, resulting in an average residual water weight of 0.15 g. Actual performance may vary depending on environmental conditions.
11. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli in self-cleaning mode, over 99.99% of bacteria were effectively eliminated. Report No.: 4840125838801. Actual performance may vary depending on environmental conditions.
12. Based on internal testing conducted by the manufacturer. The roller self-cleaning rate was 99% when tested with 10 g of simulated household dust. Actual results may vary depending on environmental conditions.
13. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental conditions.
14. Based on internal testing conducted by the manufacturer. 70° steering refers to the combined rotation of both brush heads, each rotating at least 35°. Actual performance may vary depending on environmental conditions.
Back to Top
