Skip to content
Start Anniversary Sale
Roborock F25 Series
Roborock F25 Series
Smart, Smooth, Stainless
Roborock F25 Series
Smart Wet-and-Dry Cleaning
Spotless with a Single Stroke
JawScrapers™
Complete Clean
Stays Clean and Ready to Roll
Seamless and Upgraded
Maneuverability
Intelligent App and
Voice Alerts
Roborock F25 Series
Play Video
Sticky, Even Hairy Mess?
Make It No Mess.
99.99 %2
Bacteria Removal Rate
99.99 %2
Spend less time cleaning and more time living. With 20,0001 Pa suction power and a 450 RPM cleaning frequency, the Roborock F25 Series delivers spotless results in a single stroke.
Cleaning Strokes3 / min
20,000 Pa5
Suction Power
>20 N4
Downward Cleaning Pressure
<1mm
Edge-to-Edge Cleaning9
<1mm
60 min7
Battery Life under Eco Mode
410 sqm8(4,413 sqft)
Cleaning Area per Charge
JawScrapers™ Roller
Designed for Lasting Shine
Tangle Rate10
FlatReach™ 2.0
4.92-inch
Power through tight spaces with a 4.92-inch11 flat design that keeps full suction at 0°. Its ultra-low profile reaches every corner, leaving no dust behind.
DirTect™ Smart Sensor
Smarter for Superior Cleaning
Cleaning Level
4 ...
Dirt Level
Auto Detergent Dispenser
*Available on Roborock F25 ALT and Roborock F25 ACE.
Proactive Self-Washing
As you clean, the F25 series uses the DirTect™ module to detect the cleanliness level of the water, so it knows how much it should be self-cleaned, even before it is placed back in the dock. *
Moves as You Move
Small Tweak, Big Improvement
194 ℉13
5 min
Fast Drying
99.99 %14
Multiple Stages
Separation System
99.99 %14
Multiple Stages
Separation System
Intuitive to Use,
Voice Alert
Auto
Cleaning Rollers
Empty the dirty water tank
Auto
Cleaning Rollers
One-Touch App Customization*
0 0
Key Specs
Roborock F25 RT/GT
4.0kg
Dimensions (with dock)
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 40min
(Eco Mode)
Roborock F25 LT
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Roborock F25
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Roborock F25 ALT
Auto Detergent
Dispenser
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Roborock F25 ACE
Auto Detergent
Dispenser
App Customization
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Key Specs
Roborock F25 RT/GT
Roborock F25 LT
Roborock F25
Roborock F25 ALT
Roborock F25 ACE
4.0kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 40min
(Eco Mode)
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Auto Detergent
Dispenser
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Auto Detergent
Dispenser
App Customization
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
**Use of this product requires the Roborock app. The product will not function as intended without downloading the app and agreeing to the app’s Terms and Conditions.
13.Based on internal testing. The self-washing temperature refers to the temperature of the hot air outlet blowing over the water, not the temperature of the water itself. Actual results may vary depending on environmental factors.
Back to Top
