Skip to content
Start Prime Day Sale
Low-angle view of Saros 10 vacuuming debris and hair from the floor.
Next-Level
Next-Level
Suction Power
22,000Pa
HyperForce® Suction Power6
Hair Removal Rate on Carpet7
Roborock Saros 10 dock with the robot vacuum parked at the base. Roborock Saros 10 dock with the robot vacuum parked at the base.
Saros 10
Saros 10
Down To The Finest Detail
Design Award 2025 badge.
TUV SUD certification badge for maternal and infant cleaning robot testing.
UL Security Capabilities Verified Diamond badge.
Available in Two Options
Roborock Saros 10 and Saros 10 with Refill and Drainage System shown side by side.
Saros 10
Manual Water Replacement
Flexible Base Station Placement
Automated Water Replacement
Pre-Check for Installation Required
The Thinnest Roborock
to Make a Big Difference
7.98 cm
Ultra-Thin Design
Ultra-Thin Design
The RetractSense™ Navigation System lowers its LDS to pass under low-clearance areas and rises again in open spaces, all while featuring Roborock's slimmest design yet.1
Saros 10 navigation sensors shown in a technical product render.
Saros 10 passing under low furniture with its retractable navigation sensor lowered.
Meticulous LiDAR,
Meticulous LiDAR,
More Than Simply
Rising and Retracting
AdaptiLift™ Chassis
AdaptiLift™ Chassis
Overcome Barriers,
Expand Possibilities
Up to
1.57 inches
Threshold Clearance2
With a clearance of up to 1.57 inches (4cm)—featuring the industry-first AdaptiLift™ Chassis3 —Saros 10 effortlessly crosses doorways, managing 1.18 inches (3cm) thresholds with an additional 0.39 inches (1cm) track for double-layer thresholds, or up to 1.18 inches (3cm) for single-layer thresholds, ensuring uninterrupted cleanliness.
Saros 10 crossing a threshold by lifting its wheels and chassis.
Prevent Getting Stuck
AdaptiLift™ Chassis adapts to different obstacles. Saros 10 automatically optimizes the best obstacle-crossing strategy by lifting its omni wheels and drive wheels, ensuring smooth, uninterrupted cleaning even in challenging situations.
Saros 10 raised on carpet to reduce blockage from longer carpet fibers.
Saros 10 elevates the chassis up to 0.39 inches (10mm) on high-pile carpets, reducing suction port blockages from long fibers.4
Hair Tangling?
Divide and Conquer
Divide and Conquer
Hair Tangling5
SGS Performance Tested and TUV Rheinland Anti-Hair Wrap certification marks for the main brush. SGS Performance Tested and TUV Rheinland Anti-Hair Wrap certification marks for the main brush.
DuoDivide™ Main Brush
The DuoDivide™ Anti-Tangle Brush transports collected hair to the dustbin inlet in the center, where the hair is stripped off and powerfully suctioned into the dustbin.
Hair Tangling5
SGS Performance Tested and TUV Rheinland Anti-Hair Wrap certification marks for the side brush. SGS Performance Tested and TUV Rheinland Anti-Hair Wrap certification marks for the side brush.
FlexiArm™ Riser Side Brush
VibraRise® 4.0 Mopping System
Enhanced, in Pretty
Much Every Way
Mop, Unclip!
Larger, Harder, Smarter
The VibraRise® 4.0 Mopping System features a denser, more absorbent mop that locks in moisture for effective stain removal. Dual sonic vibrating zones at 4,000 times/min each, up to 8N pressure, and a 26% larger vibration area ensures superior mopping performance.9
26% Larger
Mop Vibrating Area10
Up to 8N
Up to
8N
Downward Mopping Pressure11
Up to 220 RPM
Up to
220 RPM
Side Mop Speed12
Saros 10 side mop lifting independently while cleaning along an edge. Saros 10 side mop lifting independently while cleaning along an edge.
Side Mop Independent Lifting
Saros 10 applying extra mop pressure to clean a stubborn wet stain. Saros 10 applying extra mop pressure to clean a stubborn wet stain.
Edge-to-Edge
Edge-to-Edge
Coverage
Edge and Corner Sweeping14
0.002 inches
Edge-Close Mopping14
TUV Rheinland certification mark for effective cleaning of edges and corners. TUV Rheinland certification mark for effective cleaning of edges and corners.
Adaptive Elevation
Adaptive Elevation
for Spills and Carpets
For Spills15
  • Side Brush Lifts
  • Main Brush Lifts
  • Mop Lowers
  • Vacuum Motor Stops
For Carpets
  • Side Brush Lifts
  • Main Brush Lowers
  • Mop Lifts4
Mop Removal For Carpets
  • Vibrating Mop Removed
  • Main Brush Lowers
  • Side Brush Lifts
Quadruple, Exceptional
Saros 10 features an advanced perception system with front triple structured light, an RGB camera, and VertiBeam™ lateral structured light. It offers a wider obstacle-avoidance view, minimal blind spots, and clear detection near and far with swift response.
Dodge Fast
Clean Close
VertiBeam™ lateral obstacle avoidance precisely measures the distance between the robot and side obstacles, ensuring accurate edge cleaning along furniture and objects.
RockDock® Ultra 2.0
RockDock® Ultra 2.0
Clean Deeper, Charge Faster
The RockDock® Ultra 2.0 blends sleek design with practical convenience. It features an AG-treated tempered float glass lid that opens with a simple press, while the dust cover on the water tanks ensures lasting cleanliness.
176°F Dynamic Mop Washing16
Auto Mop Detaching
140°F Heated Air Drying17
150-Min Fast Charging19
Intelligent Dirt Detection
Auto Detergent Dispenser
176°F Dock Self-Cleaning16
Warm Water Tank Refilling
The RockDock® Ultra 2.0 uses adaptive water temperatures to tackle stains, preventing starch-based stickiness, melting oil stains, and sterilizing at high temperatures to remove 99.99% of Staphylococcus aureus and Escherichia coli from the mop after self-cleaning.18
TUV Rheinland Verified mark stating the mop removes 99.99% of Staphylococcus aureus and Escherichia coli after self-cleaning. TUV Rheinland Verified mark stating the mop removes 99.99% of Staphylococcus aureus and Escherichia coli after self-cleaning.
122°F
140°F
176°F
For stubborn grease stains.16
122°F
140°F
176°F
RockDock Ultra 2.0 washing the mop with hot water. RockDock Ultra 2.0 washing the mop with hot water.
RockDock Ultra 2.0 fast-charging indicator for the Saros 10 battery.
RockDock® Ultra 2.0 fully powers a 6400mAh battery in just 150 minutes. The dock intelligently adjusts the charge needed based on the remaining area, so you don't need to wait until it's fully charged.19
Saros 10 is also available with a refill and drainage system, eliminating the hassle of manually refilling and emptying water.
Saros 10 dock connected to refill and drainage lines.
Saros 10 cleaning quietly in a home environment. Saros 10 cleaning quietly in a home environment.
The Quietest
The Quietest
Roborock Yet
52 dB(A)
Quiet Mopping Mode21
72 dB(A)
Dock Self-Emptying21
Matter smart home compatibility icon.
Easy-to-Use App
Tap, Tap, Clean
Roborock app shown on a smartphone. Roborock app shown on a smartphone.
Roborock SmartPlan™ 2.0
Saros 10 intelligently identifies floor types and room categories, and customizes the optimal cleaning strategy based on each area and past cleaning habits.
Roborock SmartPlan 2.0 app interface customizing cleaning by room and floor type. Roborock SmartPlan 2.0 app interface customizing cleaning by room and floor type.
No Internet?
No Internet?
No Worries, It Still Works
Saros 10 responding to offline voice commands in a home. Saros 10 responding to offline voice commands in a home.
"Hello Rocky, clean here."
Saros 10 cleaning cereal spilled on the floor after a voice command. Saros 10 avoiding an area after a voice command not to clean there. Saros 10 cleaning the kitchen after a voice command. Saros 10 emptying its dustbin at the dock after a voice command.
As Always
As Always
Pick It Up
DuoDivide main brush picking up hair from carpet with rubber and bristle rollers.
Gather It In
DuoDivide main brush moving hair from both ends toward the center.
Strip It Off
DuoDivide main brush using different roller speeds to strip hair in the central gap.
Suck It In
DuoDivide main brush feeding stripped hair into the center suction inlet.
Asymmetrical Spiral Arc
Soft Rubber Baffle
Longer Side Brush Bristles
FlexiArm side brush close-up showing the asymmetrical spiral arc, soft rubber baffle, and longer bristles. FlexiArm side brush close-up showing the asymmetrical spiral arc, soft rubber baffle, and longer bristles.
& Drainage System
Saros 10 refill and drainage dock automatically refilling clean water and draining dirty water during mop washing. Saros 10 refill and drainage dock automatically refilling clean water and draining dirty water during mop washing.
Auto Water Refill and Drain
Check Your Environment
Space Requirements
Clean Water Inlet
Power Plug
Dirty Water Outlet
More than 3.3 ft (100cm)
More than 1.4 ft (42cm)
More than 1.0 ft (30.5cm)
Installation environment diagram for the refill and drainage dock showing water, power, drainage, and clearance points. Installation environment diagram for the refill and drainage dock showing water, power, drainage, and clearance points.
Strong Wi-Fi Coverage
Installation Requirements
1. Reserve a space of at least: 1.0 ft (30.5cm) in height, 1.4 ft (42cm) in width, and 3.3 ft (100cm) in depth.
4. The height difference at any point on the drainage pipeline from the ground is recommended not to exceed 1.6 ft (50cm).
5. The installation distance for the water refill and outlet pipes is recommended within 19.7 ft (6 meters). If not, please contact customer service for consultation.
6. The water pressure range is 14.5-58 PSI (0.1-0.4 MPa). If it exceeds 58 PSI (0.4 MPa), please use a pressure-reducing valve.
8. Ensure there are no thresholds, tracks, or steps higher than 0.79 inches (2cm) between the dock's installation site and the cleaning area to avoid the risk of getting stuck or missing cleaning.
Saros 10 with Refill and Drainage System dock installed compactly under a cabinet. Saros 10 with Refill and Drainage System dock installed compactly under a cabinet.
Compact Design
Seamlessly fits in your home environment and saves space with an impressive dock height of just 0.98 ft (30cm).
Your Furry Friends
Deserve the Best
Roborock app video call view showing a dog beside furniture at home.
Video Call
Dog beside spilled food while Saros 10 cleans nearby.
Saros 10 approaching a pet and stopping the main brush for pet recognition.
Roborock app showing a pet snapshot captured during cleaning.
Roborock app showing the robot searching for a pet in the home.
Other Thoughtful Features
Up to
30
Partitions Supported
Automatic Map Correction
Map correction diagram showing an extra mirrored room area highlighted for removal.
Up to
30
Saros 10
Robot (LDS Retracted)
13.78 x 13.90 x 3.14 inches
(350 x 353 x 79.8 mm)
Robot (LDS Elevated)
13.78 x 13.90 x 3.68 inches
(350 x 353 x 93.5 mm)
16.10 x 17.32 x 18.50 inches
(409 x 440 x 470 mm)
Dimension diagram for Saros 10 robot vacuum and dock.
16.10 x 17.32 x 11.81 inches
(409 x 440 x 300 mm)
Dimension diagram for Saros 10 with Refill and Drainage System.
  • Saros 10 robot vacuum and dock in a room setting.
  • Saros 10 robot vacuum cleaning a hard floor.
  • Saros 10 dock and robot vacuum shown from the front.
  • Close-up of the Saros 10 robot vacuum front sensors.
  • Saros 10 robot vacuum cleaning near furniture.
  • Saros 10 robot vacuum returning to its dock.
  • Saros 10 with Refill and Drainage System in a home setting.
  • Close-up of the refill and drainage dock.
  • Saros 10 robot vacuum with mop and brush components visible.
  • Roborock app interface for Saros 10 cleaning controls.
  • Saros 10 cleaning around household obstacles.
  • Saros 10 dock and robot vacuum shown as a product lifestyle image.
  • Custom Cleaning Routines
  • Child Lock
  • Sensient® Sensor Array
  • Quiet Mopping
Product Comparison
Roborock Saros 10 robot vacuum with standard dock. Roborock Saros 10 with Refill and Drainage System.
**Use of this product requires the Roborock app. The product will not function as intended without downloading the app and agreeing to the app’s Terms and Conditions.
2. Based on Roborock internal testing. This product is tested to cross thresholds up to 1.57 inches (4cm), including a 1.18 inches (3cm) threshold plus an additional 0.39 inches (1cm) track on top for double-layer thresholds, or up to 1.18 inches (3cm) for single-layer thresholds. Actual results may vary depending on usage conditions.
