For those who don’t compromise.
play video
A Higher Level of Convenience
· RockDock® Ultra
· 30% Faster Charging1
Long-lasting Quality
· 180 min Runtime
· Durable All-Rubber Brush
Flagship Cleaning Performance
· 5,500 Pa2 HyperForce® Suction
· VibraRise® Mopping System
Easy-to-use Intelligence
· Reactive Tech Obstacle Avoidance
· Customizable App Features
· RockDock® Ultra
· 180 min Runtime
Dries the mop and bottom of the dock to prevent unpleasant odors.
No need to wash the mop manually after use.
Allows for up to 7 weeks3 without emptying.
Fills water tank automatically for a mopping range up to 300 sqm(3230sqft)4.
Makes maintenance easy by automatically cleaning the bottom of the dock.
Self-Drying
Self-Washing
Self-Emptying
Self-Refilling
Self-Cleaning
Morning
Night
Off-peak Charging
Easy-to-use App features
Custom Cleaning Routines
Activate Carpet Boost and Deep mode to clean carpets twice in one task for better cleaning performance.
Let the robot vacuum clean the floor along its direction so the floor seams can be cleaned along the route and minimize scraping against them.
Clean your house whenever and wherever you like with custom cleaning schedules, regularly or on demand.
Simply tap your phone and let the S7 Max Ultra get to work, giving you a precise clean every time.
Long-Lasting Quality
Cleans On and On
5,200mAh Large Battery
Clean your home in one go, with up to 180 minutes of runtime.
Easily cleans up hair without tangling for minimum maintenance.
Large 200ml Water Tank
Capable of supporting the entire home8 without water refilling.
S7 Max Ultra vs S7 MaxV Ultra
Auto Mop Drying
Auto Mop Washing
Auto Tank Refilling
5,500Pa HyperForce® Suction
Auto Mop Washing
Auto Tank Refilling
5,100Pa HyperForce® Suction
ReactiveAI 2.0 Obstacle Avoidance
1. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
2. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards, using Max+ mode with a full battery. Actual results may vary according to the home environment.
3. Actual emptying interval will depend on use habits and environmental factors.
4. Based on internal testing carried out on hard floors with a full clean water tank in the Empty Wash Fill Dock using default mode. Actual results may vary, depending on the room characteristics.
5. Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20,000Hz).
6. Based on internal testing carried out by the manufacturer. Stains used for testing include coffee (dried for two hours and 24 hours), juice (dried for 24 hours), cola (dried for 24 hours) and mud (dried for 2 hours).
7. Based on internal testing carried out by the manufacturer, the mop module can be lifted up to 5mm.
8. Based on internal testing carried out on hard floors with a full electronic water tank in the robot using default mode. Actual emptying interval will depend on use habits and environmental factors.
