Start Black Friday
A Clean Sweep, Everywhere.
dyad-pro-combo dyad-pro-combo
dyad-pro-combo
Experience the power of versatility with the Dyad Pro Combo that’s got you covered whether it’s wet or dry mess.
Embrace total cleanliness anywhere you need with Roborock’s
5-in-1 combo.
5-in-1 Combo
Vanquish Wet and Dry Messes with DyadPower®
Improved Edge-to-Edge Cleaning
RevoBrush™ Self-Cleaning & Drying System
Adaptive Cleaning with DirTect™ Smart Sensor
Easy-to-Use App Control
5-in-1 Combo
The Dyad Pro Combo is a wet dry vacuum and a multi-functional handheld vacuum with diverse cleaning heads, to meet all your cleaning needs.
dyad-pro-combo
Multi-Surface
Brush
Experience optimal carpet cleaning with the Multi-Surface Brush that effectively tackles dirt and grime on carpets.
dyad-pro-combo
dyad-pro-combo
Motorized
Mini-Brush
Designed to remove dust mites and debris effortlessly, ensuring a fresh and clean sleeping environment.
dyad-pro-combo
dyad-pro-combo
2-in-1 Cleaning Head (Crevice Tool)
Get rid of dust and dirt in hard-to-reach areas, including sofa crevices, ceiling and car seats, with ease.
dyad-pro-combo
dyad-pro-combo
2-in-1 Cleaning Head (Dusting Brush)
Don’t compromise on cleaning tight spaces like curtains and keyboards, the Dusting Brush keeps them dust-free and pristine.
dyad-pro-combo
dyad-pro-combo
Wet Dry
Vacuum
Vacuum and mop simultaneously with easy push and pull, saving you time and effort.
dyad-pro-combo
dyad-pro-combo
dyad-pro-combo
dyad-pro-combo
dyad-pro-combo
Multi-Surface
Brush
dyad-pro-combo
dyad-pro-combo
Motorized
Mini-Brush
dyad-pro-combo
dyad-pro-combo
dyad-pro-combo
dyad-pro-combo
dyad-pro-combo
dyad-pro-combo
Wet Dry
Vacuum
Dyad Power® Power®
As a wet dry vacuum, DyadPower® uses multi-rollers that rotate in opposite directions to ensure that no dirt is left behind.
dyad-pro-combo
Clean More with 17,000 Pa of Suction Power
Featuring the DyadPower® cleaning head with 17,000 Pa1 of suction power, wet and dry messes simply have nowhere to go.
Unmatched Mopping Performance
20N2 consistent pressure ensures a thorough clean, effortlessly tackling the toughest stains.
With unbelievable suction power and improved rollers, all mess is removed, leaving behind the cleanest floor.
Improved Edge-to-Edge Edge-to-Edge Cleaning
The Dyad Pro Combo provides cleaning on both sides thanks to the two front rollers sweeping up messes with margins of less than 1mm3.
1mm
1mm
RevoBrush™ RevoBrush™ Self-Cleaning & Drying System
Self-Cleaning
Automatically transform your rollers from dirty to clean in an instant, without lifting a finger. Mess doesn't stand a chance with more than 99%4 of dirt being removed from the rollers, thanks to its alternating scrubbing.
Self-Drying
With 50℃5 hot air and three rows of air outlets providing complete and thorough drying, it effectively prevents odors, making maintenance a breeze.
50°C
Cleaning Made Smarter with DirTect™ DirTect™ Smart Sensor
The Dyad Pro Combo automatically adjusts its cleaning power and water flow for the perfect clean when detecting how dirty the floor is. The on-screen LED indicator tells you where the dirt is so you know where to focus.
Clean Like a Pro with the Auto Auto Dispenser
The cleaning solution can be adaptively dispensed depending on floor stains and is also adjustable on the App, to give you a perfect clean.
20 tanks6
Water Cleaning Volume
700 min6
Auto Dispenser Duration
dyad-pro-combo
App Connectivity
Easily connects to the Roborock App for your convenience. Need to use the RevoBrush™ Self-Cleaning & Drying System? Need to change the cleaning mode? These options (and more) are a tap away.
Cleaning rollers.
Voice Alerts
Durable Design Durable Design for Longer, Efficient Cleaning
The Dyad Pro Combo uses its battery at a 30% higher efficiency when compared to the Dyad. With industry-leading battery efficiency, it allows you to deep clean your entire floor, providing a maximum cleaning range of up to 300 sqm (3230sqft)7, on a single charge.
950ml Clean Tank Size
770ml Dirty Tanks Size
43min Battery Life
300sqm(3230sqft) Cleaning Range
30% Higher Battery Efficiency (vs Dyad)
As a handheld vacuum, it features a 465ml dustbin and remarkable battery life of up to 60 minutes6, guaranteeing uninterrupted cleaning power for extended periods.
465ml Dustbin
60min Battery Life
Dyad Pro Combo Dimensions
Wet Dry Vacuum
305*270*1112 mm
Bundle
532*360*1136 mm
dyad-pro-combo
Dyad Pro Combo Dyad Pro Dyad
Dyad-Pro-Combo Dyad-Pro Dyad
5-in-1 Combo
Multi-Rollers
Multi-Rollers
Multi-Rollers
1mm Edge Cleaning
1mm Edge Cleaning
2mm Edge Cleaning
RevoBrush™ Self-Cleaning and Drying System
Self-Cleaning
App Connectivity
App Connectivity
43 min Runtime (Wet Dry Vacuum)
60 min Runtime (Handvac)
43 min Runtime
35 min Runtime
Dyad Pro Combo   vs   Dyad Pro   vs   Dyad
Dyad-Pro-Combo
Dyad Pro Combo
Dyad-Pro
Dyad Pro
Dyad
Dyad
5-in-1 Combo
Multi-Rollers
1mm Edge Cleaning
App Connectivity
43 min Runtime
(Wet Dry Vacuum)
Multi-Rollers
1mm Edge Cleaning
App Connectivity
43 min Runtime
Multi-Rollers
2mm Edge Cleaning
Self-Cleaning
35 min Runtime
2. Based on internal testing carried out by the manufacturer.
3. Based on internal testing carried out by the manufacturer, rollers approached 1mm to the edges of walls.
4. According to Roborock’s internal experiments conducted with dirt and cat hairs.
5. Based on internal testing carried out by the manufacturer, with a full battery.
6. Based on internal testing carried out by the manufacturer, with a full battery, conducted in Auto Mode.
7. Based on internal testing using ECO mode. Actual results may vary depending on environmental factors.
