Skip to content
Start Prime Day Sale
S7 MaxV Series
S7 MaxV Series
Fully Automated Empty Wash Fill Dock
ReactiveAI 2.0 Obstacle Avoidance
Enhanced Hazard Recognition
5100 Pa Suction Power
VibraRise® Mopping System
Auto Dust Emptying Dock
S7 MaxV Ultra
Everything Made Easy
Play Video
red dot red dot red dot red dot red dot red dot red dot red dot
From Digital Trends. © 2022 Digital Trends Media Group. All rights reserved. Used under license.
From TIME. © 2022 TIME USA LLC.. All rights reserved. Used under license.
Vacuum more. Mop more. While emptying less, cleaning less, and doing less. Roborock S7 MaxV, combined with the Empty Wash Fill Dock, unleashes a new level of floor cleaning automation.
Fully Automated
ReactiveAI 2.0
Obstacle Avoidance
Enhanced Hazard
Recognition
5100 Pa1
Suction Power
VibraRise®
Mopping System
One Dock to Rule Them All
The Empty Wash Fill Dock is Roborock’s most advanced dock to date,
unleashing a world of new conveniences for those that demand the cleanest of floors.
Self-Washing
A unique washing system washes robot mop during cleanup and when finished.
Self-Washing Self-Washing
Self-Washing
01
02
03
04
Self-Washing
Self-Refilling
Refills the robot water tank during cleanup for a mopping range of up to 300sqm (3230sqft)2.
01
02
03
04
Self-Refilling
Self-Cleaning
Self-cleaning design cleans itself, too, for even easier maintenance.
01
02
03
04
Self-Cleaning
Self-Emptying
Auto-dustbin emptying means up to 7 weeks3 without changing a bag.
01
02
03
04
Self-Emptying
animation
Fast Charging
Recharge 30% faster4 and get back to cleaning sooner.
Off-Peak Charging Supported
30%
Faster
Fast Charging Roborock S7 MaxV Fast Charging Roborock S7 MaxV
PreciSense™
LiDAR Navigation
RGB Camera
Structured Light
3D Scanning
lightning
Fast Charging
All-Knowing Intelligence
ReactiveAI 2.0 combines structured light 3D scanning – a process which uses a pattern projected on a scene and uses pattern deformation to recognize obstacles accurately – and an all-new neural processing unit designed to execute Roborock’s machine learning algorithms, to make S7 MaxV think smarter, work faster, more easily than ever.
22%
More Accurate5
70%
Faster5
Roborock S7 MaxV has all-knowing intelligence
PreciSense™
LiDAR Navigation
RGB Camera
Structured Light
3D Scanning
See it. Dodge it
Floors in busy homes are a minefield of socks, toys, mugs, and more. Structured light 3D scanning accurately identifies the location and size of obstacles and hazards, in both bright and dark rooms, for worry-free cleaning at any time of day.
* Based on internal testing carried out by the manufacturer, S7 MaxV can see and bypass objects down to as small as 5cm (2in) wide, and 3cm (1.1in) tall. Recognition accuracy may vary depending on environmental factors.
Roborock S7 MaxV see and dodge obstacles
sun
moon
Recognize and React
Many things can trap a robot, from scales to wires, shoes, and even pet waste. Powered by machine learning and a dedicated neural processing unit, S7 MaxV recognizes these hazards and reacts differently based on what it sees. Getting up close to dropped shoes but staying far away from pet waste. Even threading its way carefully between hazards.
Roborock S7 MaxV recognizes and reacts different hazards Roborock S7 MaxV recognizes and reacts different hazards
Your Virtual Home
Recreate your home, along with all your furniture and floor types, right in the Roborock app. Automatically. During a clean S7 MaxV drops furniture it has recognized in position. Need to clean around the bed after a lazy breakfast? Just tap on your bed.
You can even view your home with a 3D map or navigate around it digitally with the Matrix map6.
* App interface is subject to change without notice.
Navigate Roborock S7 MaxV with 3D map or Matrix map to clean Navigate Roborock S7 MaxV with 3D map or Matrix map to clean
Navigate Roborock S7 MaxV with 3D map or Matrix map to clean Navigate Roborock S7 MaxV with 3D map or Matrix map to clean Navigate Roborock S7 MaxV with 3D map or Matrix map to clean Navigate Roborock S7 MaxV with 3D map or Matrix map to clean Navigate Roborock S7 MaxV with 3D map or Matrix map to clean
Tailored Room Cleaning
map
Using your furniture, S7 MaxV automatically recognizes bedrooms, living rooms, dining rooms, and bathrooms and will recommend the right amount of suction power and scrubbing intensity for each room.
lock lock
Privacy
Privacy
Privacy
It can’t be said enough that privacy and security are critical when you have a camera roaming your home. That is why for the purposes of obstacle avoidance, ReactiveAI 2.0 does not save a single image. No images saved means no images to lose7. Not only that, S7 MaxV is certified as a safe, smart home product by TUV Rheinland and also meets ETSI EN 303 645 cyber security standards.
Pascal
5100Pa
More Suction? Done and Dusted
The suction power has been cranked up. All the way up. From a maximum of 2500 Pa on the Roborock S6 MaxV all the way to 5100Pa1 on the S7 MaxV. That’s more than double the power. Fire up the Max+ mode, and all that power is yours.
Ready to Rise Up
Got carpets? Like freshly mopped floors? Perfect. Intelligent mop lifting means when a carpet is detected, the mop is lifted out of the way8. Now you can get mopped floors and vacuumed carpets in one single clean9.
Roborock S7 MaxV suction power has a maximum of 5100 Pa
Mop with the Power of Sound10
Experience robot mopping like never before, with VibraRise® sonic vibration technology that scrubs your floors up to 3,000 times per minute10 with consistently high pressure throughout the clean.
Upgraded Floating Brush
A durable all-rubber brush effectively resists hair tangles. It stays closer to even uneven floors through its multi-plain floating mechanism.
Roborock S7 MaxV with upgraded floating all-rubber brush
Check In for a Chat
Remote viewing has now been upgraded, so you can do more than just talk at the people at home. With an onboard mic, you can now talk with them no matter where you are.
Roborock S7 MaxV upgrades remote viewing and enables a chat with onboard mic
Check In for a Chat
Roborock S7 MaxV upgrades remote viewing and enables a chat with onboard mic Roborock S7 MaxV upgrades remote viewing and enables a chat with onboard mic
Product
Album
Roborock S7 MaxV design
Roborock S7 MaxV view
Roborock S7 MaxV image
Roborock S7 MaxV technologies
PreciSense™ LiDAR Navigation
ReactiveAI 2.0 System
Adaptive Route Algorithms
3D Mapping Support
Washable E11 Rated11 Air Filter
Automatic Room Recognition
ScratchSafe™ Wheels and Brushes
Sensient™ Sensor Array
Child Lock
S7 MaxV Ultra S7 MaxV Plus S7 MaxV
Roborock S7 MaxV Ultra Roborock S7 MaxV Plus Roborock S7 MaxV
Auto Mop Washing
Auto Tank Refilling
ReactiveAI 2.0
Obstacle Avoidance
ReactiveAI 2.0
Obstacle Avoidance
ReactiveAI 2.0
Obstacle Avoidance
VibraRise®
Mopping System
VibraRise®
Mopping System
VibraRise®
Mopping System
5100Pa1 Suction
5100Pa1 Suction
5100Pa1 Suction
S7 MaxV Ultra vs S7 MaxV Plus vs S7 MaxV
S7 MaxV Ultra
S7 MaxV Plus
Roborock S7 MaxV
S7 MaxV
Auto Mop Washing
Auto Tank Refilling
ReactiveAI 2.0
Obstacle Avoidance
VibraRise®
Mopping System
5100Pa1 Suction
ReactiveAI 2.0
Obstacle Avoidance
VibraRise®
Mopping System
5100Pa1 Suction
ReactiveAI 2.0
Obstacle Avoidance
VibraRise®
Mopping System
5100Pa1 Suction
Images and videos are for illustration purposes only and may not exactly represent the product.
1.
Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max+ mode with a full battery. Actual results may vary according to the home environment.
2.
Based on internal testing carried out on hard floors with a full clean water tank in the Empty Wash Fill Dock using default mode. Actual results may vary, depending on the room characteristics.
3.
Actual emptying interval will depend on use habits and environmental factors.
4.
Compared to previous Roborock docks. Improved charging speed is only available for the S7 MaxV Ultra.
5.
Compared to Roborock S6 MaxV, actual results may vary, depending on the environmental factors.
6.
Matrix Map is currently available on iPhone 12 Pro, iPhone 12 Pro Max, iPhone 13 Pro and iPhone 13 Pro Max only.
7.
Some optional settings and features may require additional data collection and processing.
8.
9.
Automatic mop lifting is only suitable for low-pile carpets no higher than 4mm.
10.
Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20,000Hz).
11.
Produced and tested by an independent third party in accordance with EN 1822-1:2019 standards.
