Skip to content
Start
Why a Wet Dry Vacuum?
Vacuum and Wash in One Pass, Saving More Time with Every Clean
Traditional Cleaning
Clean. Rinse. Repeat.
10–15 minutes
Wet Dry Vacuum
Vacuum and Wash. In One Pass
1–2 minutes
Better Together
Wet Dry Vacuum & Robot Vacuum
They work in different ways — and together, they cover it all.
Wet Dry Vacuum
Best for heavier messes and deeper floor cleaning
Mixed Wet & Dry Messes
Hair
Dried Stains
Grease
Robot Vacuum
Best for everyday upkeep and lighter mess.
Dust
Hair
Crumbs
Spills
Different strengths, different roles
— better together for everyday floor care.
Find Your Perfect Roborock F25
FAQ
  • 1. Why do I need a wet dry vacuum?
    A wet dry vacuum cleans wet and dry messes at the same time, so you can vacuum and mop in one pass for faster, easier everyday cleaning.
  • 2. What can the Roborock F25 Series do for me?
    The Roborock F25 Series is designed to handle everyday floor messes with ease, from pet hair and paw prints to sticky spills and kitchen messes.
  • 3. Is a wet dry vacuum better than a traditional mop and vacuum?
    For everyday hard-floor cleaning, it can be a more convenient choice. It combines vacuuming and mopping in one step, helping save time and effort.
  • 4. What types of messes can a wet dry vacuum handle?
    It is made for everyday hard-floor messes like dust, crumbs, hair, muddy footprints, spills, and sticky stains.
  • 5. Is the Roborock F25 Series suitable for homes with pets and kids?
    Yes. It is built for busy homes and everyday messes, making it easier to keep floors clean around pets, kids, and daily activity.
  • 6. Who is a wet dry vacuum ideal for?
    A wet dry vacuum is especially ideal for pet owners, families with multiple children, and people who cook often, where wet and dry messes are more likely to happen together.
1. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli under steam mode, over 99.99% ofbacteria on the floor were effectively eliminated. Report No.: 704012501495-01. Actual performance may vary depending on envirormental conditions.
2. Based on TÜV SÜD testing of pollen, cat dander, dog dander, aand dust mite allergen under steam mode, over 99.9% of allergenis on the floor were effectivelyremoved. Report No.: 704012505041-00. Actual performance may vary depending on environmental conditions.
3. Based on SGS testing, the hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet long hair across all four operation modes undercontrolled testing conditions. Report No.: SHES250100116672. Acttual performance may vary depending on environmental conditions.
4. Based on internal testing by the manufacturer. The stated 356°F refers to the steam temperature measured at the internaheater output, not at the steamoutlet. Actual performance may vary depending on environmmental conditions.
5. Based on internal testing by the manufacturer. The stated 1877F refers to the hot water temperature measured at the interihal heater output, not at the wateroutlet. Actual performance may vary depending on environmental conditions.
6. Based on internal testing by the manufacturer according to lEC 62885-2:2021/5.11 standards. Actual performance may vary depending on environmentalconditions.
7. Based on internal testing by the manufacturer. The stated 356°F refers to the steam temperature measuredat the internal heater output, not at the steamoutlet. Actual performance may vary depernding on environmental conditions.
8. Based on internal testing by the manufacturer. The stated 194°F refers to the temperature of the hot air outlet blowing oveer the water, not the temperature ofthe water itself. Actual performance may vary depending orn environmental conditions.
9. Based on internal testing by the manufacturer. The stated 203℉ refers to the temperature of the hot air outlet blowing over the waternot the temperature of the water itself. Actual performance may vary dependingon environmental conditions.
10. Based on internal testing. The self-washing & self-drying temperature refers to the temperature of the hot air outlet blowing over the water, not thetemperature of the water itself. Actual results may vary depending on environmental factors.
