Skip to content
Start Anniversary Sale
Welcome to Roborock CES 2026
Booth #52632, Venetian Expo, Halls A–D, Las Vegas, NV
Roborock Schedule
Activity
Time
Site
New Product Launch Keynote
2026/01/06 14:00 (UTC−8)
ShowStoppers
2026/1/6 18:00 - 21:00 (UTC-8)
Grand Ballroom, Bellagio Hotel & Casino, Las Vegas, NV
Roborock CES Booth Display
06/01/2026 - 09/01/2026
Map
Newly Launched
Robot Vacuums
Wet Dry Vacuums
Cordless Vacuum Cleaners
Lawn Mowers
Roborock-ces-Real-Madrid-CF
Saros 20
AdaptiLift™ Chassis 3.0: Up to 4.5cm + 4cm¹ Threshold Crossing
StarSight™ Autonomous System 2.0: Precise Navigation and Obstacle Recognition
35,000 Pa HyperForce® Motor² & Dual Anti-Tangle System
Qrevo Curv 2 Flow
SpiraFlow™ Real-Time Self-Cleaning Mop
2.5X Boosted Mopping Pressure³
Innovative Roller Shield
*Product availability is subjected to regional differences.
1. This product is tested to cross thresholds up to 8.5cm, including a 4.5cm threshold plus an additional 4cm track on top for double-layer thresholds, or up to 4.5cm for single-layer threshoblds. Actual results may vary depending on environmental factors.
2.Based on internal testing of the digital motor under specific conditions. Actual results may vary depending on product configuration and usage conditions.
3. Compared to the Roborock Qrevo Curv with mopping pressure up to 6N. The current model delivers mopping pressure up to 15N, based on internal testing conducted by the manufacturer. Actual performance may vary depending on home environments.
Roborock F25 Ultra
VaporFlow™: Engineered for Stubborn Messes & Hygienic Cleaning
WaveFlow™: Built for Greasy Buildup
Elevated 22,000 Pa Suction Power¹
Roborock F25 ACE Pro
JetFoaming™ Cleaning: 167 million³ ultra-dense bubbles dissolve stains and odors².
JawScrapers™ Anti-Tangle Structure
25,000 Pa Suction Power¹
35% Larger, 1,000ml Clean Water Tank⁴
2. Based on internal testing carried out by the manufacturer. Stains refer to common household messes such as grease, sauces, coffee. Odors refer to Ammonia,Trimethylamine, and Hydrogen Sulfide.
4. Compared with the Roborock F25 ACE, which is equipped with a 740 ml water tank.
Roborock H60 Hub Series
All-in-One Auto-Empty Dock
Up to 210AW¹ Suction Power
Roborock H60 Series
Up to 210AW Suction Power²
Flexible and Bendable Wand
1. Available on Roborock H60 Hub Ultra. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions.
2. Available on Roborock H60 Ultra. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions.
RockMow X1 LiDAR
Sentisphere LiDAR Environmental Perception
Four-Wheel Drive (4WD)
Patented Active Steering System
Moments
Follow Us
Contact Us
Marketing
Press inquiries
uspr@roborock.com
Influencer collaboration
uskol@roborock.com
Distribution
rrdistributor@roborock.com
Back to Top
