Dyad
Wet Mess. Dry Mess.
Make it No Mess.
subscribe
Wet Mess. Dry Mess.
Make it No Mess.
subscribe
Clean better with more rollers2. One full-length main roller plus two rear rollers equal massive cleaning power. Right to both edges of the cleaning head, leaving dirt no escape.
Whip smoothly around chair legs, table legs, and people’s legs with an agile cleaning head. And with two counter-rotating rollers, you can push and pull using just one finger.
Push a button and transform your dirty rollers into clean ones. After cleaning, solid dirt is split from dirty water in the dirty tank. All that’s left for you to do is empty it.
Clean smart, not hard. In a fight against tough stains, adaptive cleaning turns up suction and water automatically. In tandem, an on-screen indicator tells you how dirty your floor is. Now you know where to focus.
Deep clean your entire floor, with up to 280sqm (3000)sqft maximum cleaning range on a single charge3. Bathroom floor soaked after a shower? You can dry that up, too. Using a dedicated Floor Drying mode.
When you want an even more powerful clean, a floor cleaner created for Roborock by Unilever is ready to help. Derived from plants and scented with tea tree oil, this cleaner amplifies the cleaning power and leaves your home smelling fresh.
*Cleaning solution only available as a separate purchase.
1. As of January 4, 2022.
2.Based on internal testing carried out by the manufacturer according to section 5 of the IEC standard 62885-6 (wet hard floor cleaning tests), the multi roller system removes dry stains on hard flat floors more efficiently than single roller systems. Dried test stains include coffee, ketchup, mustard, and soy sauce stains.
3.Based on internal testing carried out by the manufacturer in Auto mode and traveling at a speed of 0.5m/s. Actual results may vary based on actual home environments, general cleanliness, cleaning habits, and more.
