Start Black Friday
Login
Rules
Event Rules
Q5 Series
Q5 Series
Auto-Empty Dock Pure Support
2700 Pa Suction Power
PreciSense® Precision LiDAR
3D Mapping
Custom Cleaning Routines
3D Mapping
This is a image q5 background
This is a image q5 This is a image
Simple Cleaning. Simpler Emptying.
Simple Cleaning.
Simpler Emptying.
This is a image red dot
This is a image second background
27001 Pa Suction Power 27001 Pa
Suction Power
PreciSense® Precision LiDAR PreciSense®
Precision LiDAR
3D Mapping
Custom Cleaning Routines Custom Cleaning
Routines
Auto-Empty Dock
Pure Support
This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale
This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale This is a image inhale
This is a image machine
3D Mapping
Auto-Empty Dock
Pure Support
This is a image third machine This is a image third machine
Leaves Dirt
nowhere to hide.
A maximum suction power of 27001 Pa effortlessly makes dirt disappear from your floors and carpets.
Cleans hard,
Cleans fast.
A floating main brush stays close to the ground on hard floors and raises up to agitate carpets more strongly. Especially effective in the fight against pet hair.
Compatible with
All-Rubber Brush
* Sold Separately
Effectively resists hair tangles
This is a image brush
This is a image carpet
Leaves Dirt
nowhere to hide.
Cleans hard,
Cleans fast.
Compatible with
All-Rubber Brush
* Sold Separately
This is a image main brush
This is a image This is a image This is a image This is a image This is a image This is a image This is a image This is a image This is a image This is a image
This is a image Dust bag
This is a image Without Emptying
Handles your dirty work.
The Auto-Empty Dock Pure means you no more emptying the robot dustbin. It does it for you, pulling dust into its 2.5 L dust bag, good for up to 7 weeks2 of cleaning. The dustbag is also an effective air filter, tested to filter 99.7% of pollen as small as 0.3 microns3 , helping keep your air clean.
Keeps going on... on… and on.
Powered by high-capacity 5200 mAh Li-ion battery and a 470 ml dustbin, you get long lasting cleaning that can easily tackle most homes in one clean.
  • 3230sqft
    Maximum vacuuming range4
  • 180minutes
    Maximum runtime4
Smarter than you’d imagine
Roborock's PreciSense® LiDAR navigation system is the brains behind your robot, creating maps that power a suite of features like:
3D Mapping
Take a fresh look at your home and get a clearer understanding of your layout with 3D Mapping. You can even add furniture and floor materials to recreate your home virtually.
Custom Routines
Cook a lot? Have messy kids or pets? Always finding yourself creating custom one-off cleanups? Now you can create a Routine for all these frequent but ad-hoc uses. Pick a time, cleaning mode, and the room(s) you need, and it will repeat automatically.
Multi-Level Mapping
Many homes have multiple levels. Multi-level mapping systems automatically recognize distinct levels of your home. All you have to do is put the robot down. No additional docks, no need to identify the level in your app. Up to four levels supported.
No-Go Zones and Invisible Walls
No-Go Zones define an area that the robot cannot go, while Invisible Walls draw a line and are good for sealing off rooms and corners. Every level in your home can have up to 10 No-Go Zones and 10 Invisible Walls.
3D Mapping
Custom Routines
Multi-Level Mapping
Loves a shout out.
Start cleanups, tackle specific rooms, and more. Just say the magic words. Perfect for when you don’t have a phone in hand. Amazon Alexa, Google Home, and Apple Siri Shortcuts supported.
Loves a
shout out.
Relax. Everything is under control.
Equipped with the Sensient® Sensor Array, your robot quite possibly moves more safely than you. Cliff sensors, accelerometers, bumpers, and more prevent it rolling off steps, getting trapped, or slamming into walls.
Product Album
Product Album
PreciSense® LiDAR Navigation
3D Mapping Support
Adaptive Route Algorithms
Washable E11 Rated5 Air Filter
ScratchSafe® Wheels and Brushes
Available
Combinations
Roborock Q5+
This is a imageAuto Dust Emptying
This is a image2700Pa Suction
This is a imagePreciSense® Precision LiDAR
This is a image3D Mapping
This is a imageCustom Cleaning Routines
Roborock Q5
See More Detailed Comparisons
*Images and videos are for illustration purposes only and may not exactly represent the product.
1Based on internal testing conducted by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max mode with a full battery. Actual results may vary according to the home environment.
2Actual emptying interval will depend on use habits and environmental factors.
3Based on testing carried out by an independent lab according to ISO/TS 11155-1-2001 and PT-22-000-100650 standards.
4Based on internal testing carried out by the manufacturer in Quiet mode on hard floors with a full battery. Actual results may vary according to the home environment.
5Produced and tested by an independent third party in accordance with EN 1822-1:2019 standards.
